ProjeQtOr free project management software - pdf/print problem - ProjeQtOr
pdf/print problem
19 Nov 2012 08:38 #1 by ekolossov
pdf/print problem was created by ekolossov
Looking like in v.3.0 something changed in PDF/printing. If before it have been possible to print the full width of wide page using Bullzip (and will be automatically scaled to fit the page), now it trankating page the same way as create PDF option.
Evgueni
19 Nov 2012 14:09 - 19 Nov 2012 14:09 #2 by babynus
Replied by babynus on topic Re: pdf/print problem
Could you explain more explicitly what is PDF/Print ?
Does it mean Print and then export to PDF (with external tool) or export to PDF (internal function) and then Print generated PDF ?
Which item do you try to print/export ?
There was a change in PDF export for planning and resource planning on V2.6.0, but nothing in V3.0.0.
Last edit: 19 Nov 2012 14:09 by babynus.
19 Nov 2012 14:16 #3 by ekolossov
Replied by ekolossov on topic Re: pdf/print problem
I mean in both cases: 'Export to PDF' and 'print report'.
Good sample - work->work monthly report. It will create just 11 columns for Export to PDF from 32 columns I have
Evgueni
19 Nov 2012 19:30 #4 by babynus
I cannot reproduce.
Could you post a print screen ?
20 Nov 2012 08:30 #5 by ekolossov
Screenshot enclosed
20 Nov 2012 09:22 #6 by babynus
Thnaks.
I'll investigate.
Do you have traces (print screen) of previous behavior ?
