ProjeQtOr free project management software - 3.0.0 RC - ProjeQtOr
3.0.0 RC
12 Nov 2012 12:18 #1 by JFOC
3.0.0 RC was created by JFOC
I just download 3.0.0 RC and trying to upgrade from 2.6.3, and I found some strange things happened.
1. first time login to 3.0.0 RC is not possible and the password is showed in URL (GET method ?)
2. I should choose 'Change Password' to make it upgraded to 3.0.0 RC
3. navigation right button for toolbar is in wrong position
Note:
Browser : Safari 6.0.2
OS: MacOS 10.8.2
Thank you
Web Hosting and Server Provider
Web Site: www.jfoc.net
12 Nov 2012 13:34 #2 by babynus
Replied by babynus on topic Re: 3.0.0 RC
What is the behavior ?
No OK button ? No effect on OK Button click ? Error message ?
Did you get any Javascript error ?
Did you get any error reported in the log file ?
Do you mean in the url field of the brower ? And not coded ?
It is very strange, as password is only sent through Ajax (so no visibile in the browser) and only encoded ...
Then you got the "Database update" message ? Before of after redirection to password change screen ?
I can see it on your print screen. In fact, it is in right position, but buttons should not be seen on rightmost side...
OS: MacOS 10.8.2
This is it :woohoo: The bug is here B) Move to Linux ! :evil:
(sorry, I could not resist) :blush:
I never produced this issues your're facing.
I tested on Chrome, IE (8 & 9) and FireFox, without issue.
I'll try Safari for windows (sorry, I don't have a Mac ;) )
12 Nov 2012 14:01 - 12 Nov 2012 14:02 #3 by babynus
Very strange. :huh:
I could not reproduce your issues. :silly:
No password display.
Toolbar button correctly placed.
Did you try to refresh your browser cache ?
Last edit: 12 Nov 2012 14:02 by babynus.
12 Nov 2012 14:01 #4 by JFOC
Replied by JFOC on topic Re: 3.0.0 RC
There is OK button but after ENTER its kept me back to login page and no error message, i dont get javascript error and no error_log
In URL field of the browser and not coded totally naked :woohoo:
Yes I got 'database update' message after changing password and after changed password i forgot is redirect to dashboard or get me back to login screen.
yes it is
Haha I'm opened on macos+safari but the server it self is linux+apache, I will try to open on my linux box
that should be same as long as safari.
Thank you
12 Nov 2012 14:03 #5 by JFOC
babynus wrote: Very strange. :huh:
That shouldnt be browser cache problem as I was open the page after sometimes the caches was cleaned
16 Nov 2012 18:03 #6 by bersyl91
Replied by bersyl91 on topic Re: 3.0.0 RC
I think I've got a similar issue, but not exactly the same:
- unzipped V3.0.0 (in a new directory-is it an error?)
- gone through configuration screen
- clicked on "continue" and driven directly to login screen - no upgrade at all of database.
Now, I got a connection error and the log file says:
2012-11-16 17:59:53 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projectorria.user' doesn't exist
2012-11-16 17:59:53 ***** ERROR ***** For query : desc user
2012-11-16 17:59:53 ***** ERROR ***** Strack trace :
2012-11-16 17:59:53 ***** ERROR ***** #0 Sql->query called at [/opt/projectorria/model/persistence/SqlElement.php:1689]
2012-11-16 17:59:53 ***** ERROR ***** #1 SqlElement->getFormatList called at [/opt/projectorria/model/persistence/SqlElement.php:1491]
2012-11-16 17:59:53 ***** ERROR ***** #2 SqlElement->getDataType called at [/opt/projectorria/model/persistence/SqlElement.php:1108]
2012-11-16 17:59:53 ***** ERROR ***** #3 SqlElement->getSqlElementsFromCriteria called at [/opt/projectorria/tool/loginCheck.php:35]
2012-11-16 17:59:53 ***** ERROR ***** For query : select * from user where user.name='bernard' and user.isUser = '1'
2012-11-16 17:59:53 ***** ERROR ***** #0 Sql->query called at [/opt/projectorria/model/persistence/SqlElement.php:1133]
2012-11-16 17:59:53 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/opt/projectorria/tool/loginCheck.php:35]
2012-11-16 17:59:53 ===== TRACE ===== Login error for user 'bernard'
