ProjeQtOr free project management software - Chinese menu doesn't work - ProjeQtOr
10 Nov 2012 15:36 #1 by bpxiong
I followed the instruction to use a Chinese menu, but it doesn't work, I just got a lot of "???"
也无风雨也无晴
10 Nov 2012 17:12 #2 by babynus
Can you post print screen of your menu and content of table Menu ?
The following user(s) said Thank You: bpxiong
10 Nov 2012 17:18 #3 by babynus
And most important : can you check the lang.js file you updated ?
It must be UTF-8 encoded and display correctly your characters.
10 Nov 2012 17:19 #4 by babynus
For information, Russian translation works fine with cyrilic letter.
So menu can use UNICODE.
11 Nov 2012 13:15 #5 by bpxiong
I use the "pt" column as Chinese and try translate some lines into Chinese.
As you told me, I checked my Lang.js file in the <pt> folder, it looks like this:
targetValue: "target value",
Team: "Team",
Term: "Term",
TestCase: "???嬚??????",
TestCaseRun: "Test case run",
TestCaseType: "Test cases type",
TestSession: "Test session",
TestSessionType: "Test sessions type",
themeBlue: "dark blue",
for the [ TestCase: "???嬚??????", ] , should be [ TestCase: "测试样例",]
I was confused.
也无风雨也无晴
11 Nov 2012 13:57 #6 by bpxiong
I edit the lang.js directly, It works.
Thanks a lot.
Once I finished the Chinese version of lang.js, I hope it could be shared in this project.
也无风雨也无晴
