ProjeQtOr free project management software - Installation fails ... - Page 2 - ProjeQtOr
02 Nov 2012 17:02 #7 by KrisTof
Replied by KrisTof on topic Re: Installation fails ...
I've information: it still not works BUT ...
I've now a message in Firebug:
NetworkError: 500 Internal Server Error - http://agence-benedetti.com/project/tool/loginCheck.php?destinationWidth=350
When calling: http://{my-website}/project/tool/loginCheck.php?destinationWidth=350 with POST params: isLoginPage=true&login=admin&password=admin
servers returns:
<span class="messageERROR" >ERROR : Impossible to load class PDO<br/>  => Not found in ../model/PDO.php <br/>  => Not found in ../model/persistence/PDO.php <br/></span><input type="hidden" id="lastSaveId" value="" /><input type="hidden" id="lastOperation" value="ERROR" /><input type="hidden" id="lastOperationStatus" value="ERROR" />
and console warns
Erreur sur le retour de xhrPost de loadContent('../tool/loginCheck.php?destinationWidth=350', 'loginResultDiv', 'loginForm', 'undefined').<br/>RequestError: Unable to load ../tool/loginCheck.php?destinationWidth=350 status: 500
But there's still nothing about this problem in log file.
If I correctly understand the problem, it means PDO must be activated, no ?
02 Nov 2012 19:01 - 02 Nov 2012 19:02 #8 by babynus
Replied by babynus on topic Re: Installation fails ...
Yes, you got it : PDO module must be enabled in PHP !!!
You must update your php.ini file to enable pdo and pdo for mysql modules.
Last edit: 02 Nov 2012 19:02 by babynus.
05 Nov 2012 11:00 #9 by KrisTof
I just asked the sysadmins to enable PDO on my VPS so I can't confirm you that everything goes fine, but there's something strange: PDO isn't used to create schema but for table creation ...
05 Nov 2012 11:15 #10 by KrisTof
Thank you very much, everything seems to go fine.
In fact for those who'd have the same problem, you have to first of all enable PDO but you also need to empty (or delete) DB schema, because app seems to try to update existing tables (and I got an error), then app creates schema and table and no problem.
:cheer: :cheer: :cheer: :cheer:
05 Nov 2012 12:23 #11 by babynus
Up to V2.6, PDO implementation is not complete.
It is in next coming version : V3.0
05 Mar 2024 11:23 #12 by Asadi
Replied by Asadi on topic Installation fails ...
I have a similar problem
after solving all the problem at configuration page of qt now when i go to home a page a page like below appears and never redirect to login page
