ProjeQtOr free project management software - copy project with V2.6 - ProjeQtOr
23 Oct 2012 18:13 #1 by JCDe
copy project with V2.6 was created by JCDe
Problem with the "copy project".
I have checked (sub Project & structure) but it copies only the project but not the activities and milestone?
Conf: Chrome Version 2.6.1
Thank you
23 Oct 2012 20:08 #2 by babynus
Replied by babynus on topic Re: copy project with V2.6
Works fine on Demo.
I "copied easyproject" to "easyproject copy" : sub-project and activities are copied.
Can you check :
- if you have any error reported in the log file
- check that all you items are in stable status : go to each item, and save item without any change. If result is "item saved", it means your item is not in stable status, and cannot be copied. It may happen where items have been copied before V2.6 : default status is not set. Since V2.6 item are copied into new status "copied".
