ProjeQtOr free project management software - Issue at login - ProjeQtOr
Issue at login
23 Sep 2012 14:48 #1 by Elarith
Issue at login was created by Elarith
As said in the title, we have a trouble at the login page...
In fact, we was downloading some .jpg files for our projects, one of it was a 2,24Mb pic. As it took too much time, we wanted to stop it, that worked. We closed the tool and we went back for login... Impossible... We just had a ERROR message...
We tried to solve it by ourselve, so we changed a line in the parameters.php file (i don't remember which one... but we change the paremeter "2" in "3"), then that was telling us it was an error in the login.php file at line 6, so we fixed it. And now we have an error in the main.php at line 11...
We are are going dizzy with it >.<'
Can smeone help us ?
Thanks in advance !
23 Sep 2012 16:29 #2 by babynus
Replied by babynus on topic Re: Issue at login
Hi
Error in login.ph at line 6 is very strange. Line 6 is
header ('Content-Type: text/html; charset=UTF-8');
How did you "fix" that ?
Error in main.php at line 11 is the same ...
No way, you should not change this code : it's working fine in "normal way".
My advise :
- stop your php service
- get back to correct code (reinstall the version if needed)
- clean the php cache (where php stores the sessions)
- restart your php service
It should get better then.
NB : for information, if upload took too much time, possibly it is because of php upload limit (default is 2MB)
