ProjeQtOr free project management software - First installation - OK button doesn't works - ProjeQtOr
17 Sep 2012 10:32 #1 by pak
Hi all
I'm trying to install Project'Or RIA on my linux local web server, and I mapped a virtual host with project.myserver.lan
I get the first configuration page, but when I click on OK nothing happen!
No error, no warning, no log in /var/log into the server
I tried to trace it with firebug, but nothing were detected...
Same behaviour both on
and
http://192.168.1.250/projectorria
- Projec'Or RIA 2.5.1
- Debian 6.0.2
- Apache 2.2.16
- php 5.3.3-7
- mysql 5.1.63
Some hints? Where I can looking for to hunt the bug?
17 Sep 2012 10:38 #2 by pak
This issue is only with 2.5.1 version
Now I've installed successfully 2.4.3
17 Sep 2012 11:44 #3 by babynus
Very strange you could deploy V2.4.3 and not V2.5.1 : no change occured on configuration on V2.5.
Can you try to deploy V2.5.1 over V2.4.3 ?
Can you check :
- access rights to directory where you defined log file (default is /files/logs)
- access rights to directory where you defined parameter file (default is /files/config)
- access rights to directory /tool (new file is written on configuration)
17 Sep 2012 11:49 #4 by pak
I double checked permission files
Both of them (2.4.3 and 2.5.1) was installed with
# chown www-data:www-data -R /var/www/projectorria
Now I have installed 2.4.3, how can I upgrade to 2.5.1? Can I simple overwrite /var/www/projectorria directory?
17 Sep 2012 12:03 #5 by babynus
Yes, just overwrite the application directory.
Then connect as admin : upgrade process (database updates) is automatic.
17 Sep 2012 12:29 #6 by ambroise1er
Hello Babynus,
Version 2.5.1: "OK" button does not work during a first installation under Windows XP as well.
- Test with Xampp1.7.7: KO
- Test with Xampp1.8.0: KO
