ProjeQtOr free project management software - Display Name - ProjeQtOr
Display Name
02 Aug 2012 17:54 #1 by gvecchi
Display Name was created by gvecchi
Is it possible to change email Display Name?
At the moment, I send email trought postfix and recipient see "www-data" as Display Name (Ubuntu default apache user).
Any idea?
02 Aug 2012 18:26 #2 by babynus
Replied by babynus on topic Re: Display Name
just update $paramMailSender in parameters.php file.
03 Aug 2012 07:56 #3 by climb4fun
Replied by climb4fun on topic Re: Display Name
Hi Babynus,
more often I thought, it would be a nice improvement, if parameters.php could be modified with the same as startup screen. This might be selectable in Administration screen.
Klaus
03 Aug 2012 08:28 #4 by gvecchi
Replied by gvecchi on topic Re: Display Name
I've just edit $paramMailSender but this one is about "from" parameter, not "Display Name".
Man sendmail:
-F full_name
Set the sender full name. This overrides the NAME environment variable, and is used only with messages that have no From: message header.
-f sender
Set the envelope sender address. This is the address where delivery problems are sent to. With Postfix versions before 2.1, the Errors-To: message header overrides the error return address.
03 Aug 2012 09:30 #5 by babynus
It is an already planned improvement : Ticket #554, planned for V2.7 ;)
03 Aug 2012 09:43 #6 by babynus
$parameterMailSender is the "From" parameter about the header defined in the mail() PHP function. Don't mismatch with unix sendMail From parameter.
You can format the from like this :
$paramMailSender="Display name <sender@compagny.com>"
