ProjeQtOr free project management software - Firefix random crashes - Page 4 - ProjeQtOr
Poll: Do you face Firefox crashing issue using Project\'Or RIA ?
No, never
3 100%
Yes, once or twice
No votes 0%
Yes, from time to time
No votes 0%
Yes, frequently
No votes 0%
Total number of voters: 3 ( LEVA, Dhemaius, babynus )
Only registered users can participate to this poll
30 Jul 2012 10:15 #19 by babynus
Replied by babynus on topic Re: Firefix random crashes
Does it crash with extention not installed ?
As you noticed it does not crash in safe mode, I think issue is on this side.
Even disabling extentions is not enough.
I had some case where an extension installed but disabled produced some unexpected behaviour.
21 Aug 2012 09:55 #20 by ekolossov
It is still crashing even when extensions not installed - just had a fresh machine to test. I am getting more and more complains about it. This MUST be fixed ASAP!!!
21 Aug 2012 11:56 #21 by babynus
Unfortunately this is not an applicative bug, and my own tests did not produce the issue (with 100 lines displayed).
The only solution could be to limit displayed lines ...
The only workaround today can be :
- try to avoid display of more than 50 lines
- use another browser (Chrome works fine, and exists as a portable application)
21 Aug 2012 12:00 - 21 Aug 2012 12:02 #22 by ekolossov
There is no link with the number of lines.
We are talking about using tool as the main tool in development process and now with all this complains it is quite questionable I would say.
People also said that in IE it is loading extremely slow.
I think that at some point you have started to use some features that Firefox not supporting - this is where problem started.
Is there other users who have the same problems? may be reason that we have something not up to date on our server?
Last edit: 21 Aug 2012 12:02 by ekolossov.
21 Aug 2012 12:27 #23 by babynus
You get crashes with less than 20 lines displayed ?
Yes, up to IE8 it is a mess. IE9 does better.
No specific feature is used. Moreover, I never could produce your issue using Firefox on my side.I will not be able to fix an issue I can not produce. That's why I requested the list of extensions you use, to try and reproduce and have a clue. But now you tell me you produce the issue without any extension, I don't know how I can help you.
Devs use Dojo framework to get cross-browser compatibility. I just checked Dojo site : new version ( V1.8 ) has been deployed. I will check changelogs to see if some fixing may concern your issue, and I plan to deploy this new version with V2.5, but there is no clue it can help on this issue.
I'd also be glad to have users feedback . Please post you freedback here, and any clue on production of the issue will help solve it.
I don't think issue is on server side (but I may be wrong), I guess it is on browser side.
21 Aug 2012 12:49 #24 by babynus
I added a poll (and voted...) to this thread to try and get feedback from other users.
