ProjeQtOr free project management software - V2.4 : problem when printing Porject in PDF format - ProjeQtOr
20 Jul 2012 16:08 #1 by Hammurabi
when i try to print a project i have this erreor :
ERROR : Une erreur est survenue le 2012-07-20 à 16:05:56
this error isn't occured when i print activity.
20 Jul 2012 16:30 #2 by babynus
You must are an error written is the log file, with the timestamp reported.
Can you please submit this error log.
20 Jul 2012 17:05 #3 by Hammurabi
2012-07-19 17:29:58 ===== TRACE ===== Login error for user 'guest'
2012-07-19 17:30:12 ===== TRACE =====
2012-07-19 17:30:12 ===== TRACE ===== =====================================
2012-07-19 17:30:12 ===== TRACE ===== DataBase actual Version = V2.1.1
2012-07-19 17:30:12 ===== TRACE ===== ProjectOR actual Version = V2.4.0
2012-07-19 17:30:12 ===== TRACE ===== VERSION V2.2.0
2012-07-19 17:30:12 ===== TRACE ===== 2 lines inserted into table "projectorria1linkable".
2012-07-19 17:30:12 ===== TRACE ===== 1 lines inserted into table "projectorria1linkable".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1link" altered.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1attachement" altered.
2012-07-19 17:30:12 ===== TRACE ===== 2 lines inserted into table "projectorria1indicator".
2012-07-19 17:30:12 ===== TRACE ===== 4 lines inserted into table "projectorria1indicatorableindicator".
2012-07-19 17:30:12 ===== TRACE ===== 1 lines inserted into table "projectorria1parameter".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1workelement" altered.
2012-07-19 17:30:12 ===== TRACE ===== 1 lines inserted into table "projectorria1report`(`id`,".
2012-07-19 17:30:12 ===== TRACE ===== 3 lines inserted into table "projectorria1reportparameter".
2012-07-19 17:30:12 ===== TRACE ===== 7 lines inserted into table "projectorria1habilitationreport".
2012-07-19 17:30:12 ===== TRACE ===== 1 lines updated into table "projectorria1menu".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1meeting" altered.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1approver" created.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1approver" altered.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1documentversion" altered.
2012-07-19 17:30:12 ===== TRACE ===== DATABASE UPDATED
2012-07-19 17:30:12 ===== TRACE ===== WITH NO ERROR
2012-07-19 17:30:12 ===== TRACE ===== VERSION V2.3.0
2012-07-19 17:30:12 ===== TRACE ===== 1 lines inserted into table "projectorria1menu".
2012-07-19 17:30:12 ===== TRACE ===== 7 lines inserted into table "projectorria1habilitation".
2012-07-19 17:30:12 ===== TRACE ===== 1 lines inserted into table "projectorria1reportparameter".
2012-07-19 17:30:12 ===== TRACE ===== VERSION V2.4.0
2012-07-19 17:30:12 ===== TRACE ===== 15 lines updated into table "projectorria1menu".
2012-07-19 17:30:12 ===== TRACE ===== 9 lines inserted into table "projectorria1menu".
2012-07-19 17:30:12 ===== TRACE ===== 56 lines inserted into table "projectorria1habilitation".
2012-07-19 17:30:12 ===== TRACE ===== 21 lines inserted into table "projectorria1accessright".
2012-07-19 17:30:12 ===== TRACE ===== 11 lines inserted into table "projectorria1type".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1risklevel" created.
2012-07-19 17:30:12 ===== TRACE ===== 5 lines inserted into table "projectorria1risklevel".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1feasibility" created.
2012-07-19 17:30:12 ===== TRACE ===== 3 lines inserted into table "projectorria1feasibility".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1runstatus" created.
2012-07-19 17:30:12 ===== TRACE ===== 4 lines inserted into table "projectorria1runstatus".
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1requirement" created.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1requirement" altered.
2012-07-19 17:30:12 ===== TRACE ===== Table "projectorria1testcase" created.
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1testcase" altered.
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1testsession" created.
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1testsession" altered.
2012-07-19 17:30:13 ===== TRACE ===== 3 lines inserted into table "projectorria1referencable".
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1linkable" altered.
2012-07-19 17:30:13 ===== TRACE ===== 2 lines updated into table "projectorria1linkable".
2012-07-19 17:30:13 ===== TRACE ===== 1 lines updated into table "projectorria1linkable".
2012-07-19 17:30:13 ===== TRACE ===== 0 lines updated into table "projectorria1linkable".
2012-07-19 17:30:13 ===== TRACE ===== 3 lines inserted into table "projectorria1linkable".
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1testcaserun" created.
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1testcaserun" altered.
2012-07-19 17:30:13 ===== TRACE ===== 0 lines updated into table "projectorria1priority".
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1dependable" altered.
2012-07-19 17:30:13 ===== TRACE ===== 2 lines updated into table "projectorria1dependable".
2012-07-19 17:30:13 ===== TRACE ===== 1 lines updated into table "projectorria1dependable".
2012-07-19 17:30:13 ===== TRACE ===== 2 lines inserted into table "projectorria1dependable".
2012-07-19 17:30:13 ===== TRACE ===== 1 lines inserted into table "projectorria1reportcategory".
2012-07-19 17:30:13 ===== TRACE ===== 4 lines inserted into table "projectorria1report`(`id`,".
2012-07-19 17:30:13 ===== TRACE ===== 15 lines inserted into table "projectorria1reportparameter".
2012-07-19 17:30:13 ===== TRACE ===== 28 lines inserted into table "projectorria1habilitationreport".
2012-07-19 17:30:13 ===== TRACE ===== Table "projectorria1dependency" altered.
2012-07-19 17:30:13 ===== TRACE ===== 0 lines updated into table "projectorria1dependency".
2012-07-19 17:30:13 ===== TRACE ===== DATABASE UPDATED
2012-07-19 17:30:13 ===== TRACE ===== WITH NO ERROR
2012-07-19 17:30:13 ***** ERROR ***** [1146] SQL Error : Table 'projectorria.habilitation' doesn't exist<br/><br/>insert into projectorria1habilitation (idProfile, idMenu, allowAccess) SELECT profile.id, menu.id, 0 FROM projectorria1profile profile, projectorria1menu menu WHERE (profile.id, menu.id) not in (select idProfile, idMenu from habilitation)
2012-07-19 17:30:13 ===== TRACE ===== =====================================
2012-07-19 17:30:13 ===== TRACE ===== DATABASE UPDATE COMPLETED TO VERSION V2.4.0
2012-07-19 17:30:24 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:31:20 ===== TRACE ===== Login error for user 'guest'
2012-07-19 17:31:24 ===== TRACE ===== Login error for user 'guest'
2012-07-19 17:31:34 ===== TRACE ===== Login error for user 'guest'
2012-07-19 17:31:41 ===== TRACE ===== Login error for user 'Guest'
2012-07-19 17:31:47 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:31:56 ===== TRACE ===== Login error for user 'guest'
2012-07-19 17:32:00 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:32:28 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:34:16 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 17:34:32 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:34:39 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 17:34:47 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:36:27 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:36:49 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 17:37:14 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:40:20 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:40:48 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:41:39 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 17:42:08 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:42:20 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 17:44:40 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:44:52 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:45:37 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 17:45:53 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 20:46:38 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 20:47:19 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 20:53:54 ===== TRACE ===== DISCONNECTED USER 'admin'
2012-07-19 20:54:03 ===== TRACE ===== NEW CONNECTED USER 'SHQRCR'
2012-07-19 21:44:18 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 21:46:50 ===== TRACE ===== Login error for user ''
2012-07-19 21:47:08 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 22:05:43 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 22:07:02 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-19 22:30:58 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 14:20:06 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 14:20:33 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 16:04:40 ***** ERROR ***** ERROR *****
2012-07-20 16:04:40 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (5138)
2012-07-20 16:04:40 ***** ERROR ***** cause = Undefined offset: 6
2012-07-20 16:04:48 ***** ERROR ***** ERROR *****
2012-07-20 16:04:48 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (5138)
2012-07-20 16:04:48 ***** ERROR ***** cause = Undefined offset: 6
2012-07-20 16:05:02 ***** ERROR ***** ERROR *****
2012-07-20 16:05:02 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (5138)
2012-07-20 16:05:02 ***** ERROR ***** cause = Undefined offset: 6
2012-07-20 16:05:56 ***** ERROR ***** ERROR *****
2012-07-20 16:05:56 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (5138)
2012-07-20 16:05:56 ***** ERROR ***** cause = Undefined offset: 6
2012-07-20 16:25:05 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 16:27:43 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 16:30:07 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-07-20 16:32:38 ===== TRACE ===== Login error for user ''
2012-07-20 16:32:45 ===== TRACE ===== Login error for user 'guest'
2012-07-20 16:33:57 ===== TRACE ===== NEW CONNECTED USER 'admin'
20 Jul 2012 19:34 #4 by babynus
Thnaks.
Anomaly confirmed and registered as Ticket #729
