ProjeQtOr free project management software - Troubles with IE7 - Page 2 - ProjeQtOr
Troubles with IE7
20 Jul 2012 15:21 #7 by Hammurabi
Replied by Hammurabi on topic Re: Troubles with IE7
actually it's not depend of me cause IE7 is the default browser in the organization ... we're now testing Projector for a global deployement ... unfortunately we haven't a project to upgrade windows xp and IE7 ...
20 Jul 2012 16:19 #8 by babynus
Replied by babynus on topic Re: Troubles with IE7
Please let me know if you get any javascript error :
Tools / Options / Adsvanced, unckeck (disable script debugger)
Run the application again.
You should get an alert on bottom left of screen.
Double click on it, will show a popu with the message.
Could you also try a previous version (V2.3.0 for instance).
24 Jul 2012 19:20 #9 by Hammurabi
problem resolved ... the problem is caused by the communication between the server and IE7 : i had an URL with a special caracter "_" and IE7 refuse to communicate with the server ...
Question for babynus : i have an error on IE 7
24 Jul 2012 23:53 #10 by babynus
Great you found the issue !
This fixing may help someone else ;)
About JS error, it's a Dojo issue on V1.7.2 of the framework.
This issue is not blocking, you can continue with it.
I'm testing V1.7.3 of dojo to see if it fixes this issue.
Some other issues on Firefox (crash) may force me to revert to previous version (V1.6.2)... this will erase this isse...
25 Jul 2012 11:38 #11 by babynus
I tested JS error on IE8 (I don't have any IE7 available any more)
- on V2.4.0 with Dojo 1.7.2 : error occurs
- on V2.4.1 with Dojo 1.7.3 : error does not occur
So it seems Dojo 1.7.3 fixes this issue ... at least on IE8. Hope it also fixes it on IE7.
