ProjeQtOr free project management software - BUG : Production of the report of work per resource (PDF) - ProjeQtOr
14 May 2012 21:13 #1 by Hammurabi
I have this error "ERROR : An error occured on 2012-05-14 at 15:12:09" when i try to produce the PDF report of the detailed work per resource (weekly, montly or annualy).
14 May 2012 22:41 #2 by babynus
There must be an error logger in the log file.
Can you post it here please ?
15 May 2012 15:10 #3 by Hammurabi
I'll post it soon cause i'm wainting for the technical support.
By the way, i want understand why we can't select a resource in this report ?
Thx
15 May 2012 15:25 #4 by babynus
Just because it was not concidered usefull.
15 May 2012 15:29 #5 by Hammurabi
All right.
but this report will be unreadble if we look over a huge collection of resources.
Thx
15 May 2012 15:39 #6 by Hammurabi
2012-05-14 09:14:10 ***** ERROR ***** [1064] Erreur SQL : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') and v
p.idVersion=projectorria1version.id)) order by projectorria1version.name' at line 1<br/><br/>select id as id, name as name from projectorria1version where (idle=0 and projectorria1version.isEis='0' a
nd exists (select 'x' from projectorria1versionproject vp where vp.idProject in () and vp.idVersion=projectorria1version.id)) order by projectorria1version.name
2012-05-14 09:17:22 ===== TRACE ===== DISCONNECTED USER 'SHQRCR'
2012-05-14 09:17:28 ===== TRACE ===== NEW CONNECTED USER 'admin'
2012-05-14 09:36:59 ***** ERROR ***** [1064] Erreur SQL : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') and v
2012-05-14 15:08:58 ***** ERROR ***** ERROR *****
2012-05-14 15:08:58 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:08:58 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:09:03 ***** ERROR ***** ERROR *****
2012-05-14 15:09:03 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:09:03 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:09:28 ***** ERROR ***** ERROR *****
2012-05-14 15:09:28 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:09:28 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:09:40 ***** ERROR ***** ERROR *****
2012-05-14 15:09:40 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:09:40 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:10:14 ***** ERROR ***** ERROR *****
2012-05-14 15:10:14 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:10:14 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:10:19 ***** ERROR ***** ERROR *****
2012-05-14 15:10:19 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:10:19 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:10:25 ***** ERROR ***** ERROR *****
2012-05-14 15:10:25 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
2012-05-14 15:10:25 ***** ERROR ***** cause = Undefined offset: 5
2012-05-14 15:12:09 ***** ERROR ***** ERROR *****
2012-05-14 15:12:09 ***** ERROR ***** on file '/var/www/vh/projector_tst/public/projectorria/external/html2pdf/html2pdf.class.php' at line (2133)
