ProjeQtOr free project management software - closed project issue - ProjeQtOr
14 May 2012 16:02 #1 by spiderjn
HI
when i clause a projet, i have already access to 'status' field.
(2.2.2)
Best regards
14 May 2012 17:08 #2 by babynus
Replied by babynus on topic Re: closed project issue
It is normal, as it is the expected way to re-open the project, if needed.
If you want to block closed projects so that they cannot be re-opended, use a dedicated workflow where it is impossible to quit "closed" status.
