ProjeQtOr free project management software - Error on real work visualisation - ProjeQtOr
11 May 2012 15:22 - 11 May 2012 15:26 #1 by jmmbb
I'm using V 2.2.0. Since this morning, there's an error reporting from only one of my project leader.
Projects are not longer visible in project list (only the first project and his subproject) and, when trying to use real work imputation, the followinf error occors :
ERROR : Undefined property: Assignment::$name
in ImputationLine.php
at line 148
It works for every other project leader. Error occurs on multiple PC, even with Firefox or IE 8.
Attached : log file
projector_20120511.log
Last edit: 11 May 2012 15:26 by jmmbb.
11 May 2012 15:42 - 11 May 2012 15:44 #2 by babynus
Issue about real work allocation is solved (Ticket #666).
Deployment of V2.2.1 coming soon...
Could you detail issue about project visibility ?
Do you mean in the list of projects, in the Project screen ?
Or project combo list in another screen ?
Did you check project selector ? Visibility always take it into account, and may automatically be positionned on connection if user defined it as default in his user parameter screen.
Last edit: 11 May 2012 15:44 by babynus.
11 May 2012 15:52 #3 by jmmbb
Thanks for solving.
Projects are no longer visible in the combo box top of screen.
11 May 2012 16:32 #4 by babynus
Issue not reproduced.
Could you detail use case ?
- Profile of concerned user
- List of projects he is affected to
- List of projects in the combo box
- List of projects he sees in the Projects screen
Regards.
