ProjeQtOr free project management software - Project'or ria first configuration problem - ProjeQtOr
14 Apr 2012 22:10 - 14 Apr 2012 22:45 #1 by mathis
I am trying to install Project'Or RIA V2.1.1 on my PC. I have wampserver running on my PC.
When the screen that helps to configure Project'Or RIA at first run appears I just click on OK button and I have changed no thing (all default). But this message written in red appears:
incorrect database parameters : wrong host or user or password
Error while trying to create Database 'projectorria' .
Is there something to change? any idea?
Last edit: 14 Apr 2012 22:45 by mathis.
14 Apr 2012 23:00 #2 by babynus
In the config screen, you must define the pramareters to access the MySql Database.
Host : if your installation is local, then set it to 'localhost' or '127.0.0.1'
User : in most cases, default installation uses 'root' user, but may be changed on mysql installation
Password : eitheir you set it manually on MySql install, or you can try 'root', 'mysql' or '' (leave blank).
Regards.
14 Apr 2012 23:09 #3 by mathis
Thanks for you very quick reply!!!
Yes!!! I had to leave the password to blank !
Thanks ! :cheer: :cheer:
16 Apr 2012 10:18 #4 by climb4fun
Hi Babynus,
a common issue - shouldn't we put in Tips&Tricks?
Klaus
16 Apr 2012 10:36 #5 by babynus
Hint added
