ProjeQtOr free project management software - Wrong link reports - gant - ProjeQtOr
05 Apr 2012 14:02 #1 by climb4fun
Hi Babynus,
if selecting in report the gant report, then work synthesis report is displayed.
V2.1.0.
Klaus
05 Apr 2012 14:07 #2 by climb4fun
Update: it's not worksynthesis report, which is displayed. If not selecting a decidated project, then only left table of gant chart will be displayed, but no gant.bars.
07 Apr 2012 15:24 #3 by babynus
I cannot reproduce this issue.
I tried with admin and project leader.
Can you check log file for reported errors ?
Did you try with several users/profiles ?
Can you also try to select each project one by one : maybe issue is linked to one project...
08 Apr 2012 19:02 #4 by babynus
Hi Klaus,
I really could not reproduce.
Could you test again ?
The only way I found to produce the behaviour your get is to select a start date after the end of last task...
