ProjeQtOr free project management software - Indicator should not work, if status is set to done - ProjeQtOr
04 Apr 2012 15:12 #1 by climb4fun
Hi Babynus,
once you save an item, then indicator will check and send Warning or Alert. That's good.
But if on due date, a task is set to done / closed -> done = 1 and/or closed = 1, then it should not check indicators.
Klaus
04 Apr 2012 15:50 #2 by babynus
Indicators are designed to work the way you describe it.
If it does not, it-s a bug.
I registered the issue as ticket #623.
