ProjeQtOr free project management software - Autoalerts seems not to work since V2.0.1 - ProjeQtOr
19 Mar 2012 12:56 #1 by climb4fun
Hi Babynus,
autoalerts seems not to work since V2.0.1. Even I press on RUN, there is no change. But If we active change an item then it works.
Klaus
19 Mar 2012 17:16 #2 by babynus
Hi Klaus,
Do you have any error logged ?
20 Mar 2012 17:54 #3 by climb4fun
Hi Babynus,
this error code is logged several times in the same manner:
2012-03-02 17:21:09 ===== TRACE ===== cron started at 02/03/2012 17:21:09
2012-03-02 17:21:29 ***** ERROR ***** ERROR *****
2012-03-02 17:21:29 ***** ERROR ***** on file '/opt/lampp/htdocs/projector/model/IndicatorValue.php' at line (234)
2012-03-02 17:21:29 ***** ERROR ***** cause = Trying to get property of non-object
Klaus
20 Mar 2012 18:26 #4 by babynus
This helps solving the issue :
In fact, it is not due to V2.0 : it is a residual issue, using some indicators (you should have added new indicators recently)
The one working with Initial Start Date, Validated Start Date and PlannedStartDate lead to the issue you are facing when they are requested.
Will be fixed in V2.1.0
20 Mar 2012 19:21 #5 by climb4fun
Yes, I can confirm fully.
