ProjeQtOr free project management software - Problem with the export MS Project XML - Page 2 - ProjeQtOr
08 Oct 2013 10:01 #7 by Garden Dwarf
I have the same with MS Project 2010 when trying to open the xml file (export from Project'Or RIA 3.4.4). If something has been made to solve this, could you please provide the workaround?
Thanks!
08 Oct 2013 13:35 #8 by babynus
Several issues may happen.
1) the namespace used does not exist anymore on Microsoft website.
Replace
<Project xmlns="http://schemas.NotAllowedScript69d24ecf37fa5microsoft.com/project">
with
<Project>
2) Some project names with tabulation car
Both are fixed and will be deployed on next version.
08 Oct 2013 13:48 #9 by Garden Dwarf
Thank you for your answer.
Here is the first 3 lines I have:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<Project xmlns="schemas.NotAllowedScript69d24ecf37fa5microsoft.com/project">
<Name>export_planning_20131008_125911.xml</Name>
I have tested with <Project> and I got the same message.
I also exported an empty project from MS Project in XML in order to compare with my export from Project'Or RIA. I noticed a UNIX/DOS format difference (Project'Or RIA is running on a Linux server whereas I try to open it under Windows) which I fixed without success (well, changing from UNIX to DOS was done with success, I meant that I got the same message again).
I have seen also a lot of variables which exists on one file but not on the other one, but I am novice into this and so not able to go further for now.
I went on MS website to check versus the MS Project XML format standards, but it can take time. So in the meantime, any other advise is welcome ;)
08 Oct 2013 14:14 #10 by Garden Dwarf
Ok, I found it.
The problem was in the <Group> section of <Resource>.
The content was "<Group>Security & Compliance</Group>" and removing the ampersand character has fixed the import.
I suspect that other fields have the same constraint.
09 Oct 2013 16:35 #11 by babynus
Ticket #1198 recorded and fixed.
09 Oct 2013 17:07 #12 by Garden Dwarf
Just one more question: fixed for this specific field, or did you checked versus other ones?
