ProjeQtOr free project management software - Error when saving RealWorkAllocation - Page 2 - ProjeQtOr
28 Feb 2012 16:01 #7 by rdevau
Sorry, the table was collapsed in firebug:
<table class="imputationTable">
<tbody>
<tr class="ganttHeight">
<tr id="line_1" class="ganttTaskgroup">
<tr id="line_2" class="ganttTaskgroup">
<tr id="line_3" class="ganttTaskgroup">
<tr id="line_4" class="ganttTaskrow">
<tr id="line_5" class="ganttTaskrow">
<tr id="line_6" class="ganttTaskrow">
<tr id="line_7" class="ganttTaskrow">
<tr id="line_8" class="ganttTaskrow">
<tr id="line_9" class="ganttTaskgroup">
<tr id="line_10" class="ganttTaskgroup">
<tr id="line_11" class="ganttTaskrow">
<tr id="line_12" class="ganttTaskrow">
<tr id="line_13" class="ganttTaskrow">
<tr id="line_14" class="ganttTaskgroup">
<tr id="line_15" class="ganttTaskgroup">
<tr id="line_16" class="ganttTaskgroup">
<tr id="line_17" class="ganttTaskrow">
<tr id="line_18" class="ganttTaskgroup">
<tr id="line_19" class="ganttTaskrow">
<tr id="line_20" class="ganttTaskrow">
<tr id="line_21" class="ganttTaskrow">
<tr id="line_22" class="ganttTaskgroup">
<tr id="line_23" class="ganttTaskgroup">
<tr id="line_24" class="ganttTaskrow">
<tr id="line_25" class="ganttTaskgroup">
<tr id="line_26" class="ganttTaskrow">
<tr id="line_27" class="ganttTaskgroup">
<tr id="line_28" class="ganttTaskrow">
<tr id="line_29" class="ganttTaskgroup">
<tr id="line_30" class="ganttTaskrow">
<tr id="line_31" class="ganttTaskgroup">
<tr id="line_32" class="ganttTaskrow">
<tr id="line_33" class="ganttTaskgroup">
<tr id="line_34" class="ganttTaskgroup">
<tr id="line_35" class="ganttTaskgroup">
<tr id="line_36" class="ganttTaskrow">
<tr id="line_37" class="ganttTaskrow">
<tr id="line_38" class="ganttTaskgroup">
<tr id="line_39" class="ganttTaskgroup">
<tr id="line_40" class="ganttTaskgroup">
<tr id="line_41" class="ganttTaskrow">
<tr id="line_42" class="ganttTaskgroup">
<tr id="line_43" class="ganttTaskgroup">
<tr id="line_44" class="ganttTaskrow">
<tr id="line_45" class="ganttTaskgroup">
<tr id="line_46" class="ganttTaskgroup">
<tr id="line_47" class="ganttTaskgroup">
<tr id="line_48" class="ganttTaskgroup">
<tr id="line_49" class="ganttTaskrow">
<tr id="line_50" class="ganttTaskrow">
<tr id="line_51" class="ganttTaskrow">
<tr id="line_52" class="ganttTaskgroup">
<tr id="line_53" class="ganttTaskrow">
<tr id="line_54" class="ganttTaskrow">
<tr id="line_55" class="ganttTaskrow">
<tr id="line_56" class="ganttTaskgroup">
<tr id="line_57" class="ganttTaskgroup">
<tr id="line_58" class="ganttTaskgroup">
<tr id="line_59" class="ganttTaskrow">
<tr class="ganttDetail">
</tbody>
</table>
28 Feb 2012 16:43 #8 by babynus
I've got an idea : maybe your request reponse is just truncated.
Possibly, it's beacause post_max_size is too small.
Try and change it in php.ini.
For instance
post_max_size = 8M
(set the modified files back to initial version before testing again)
28 Feb 2012 18:23 #9 by rdevau
I set it to 16M, but no change.
I think i'll close this ticket, the v2 is fine for me, i'll upgrade my envir.
If you want me to test some other things, hurry up, tomorrow the v2 will drive our team!
Best regards,
Rémi
28 Feb 2012 18:25 #10 by babynus
You don't have the issue on V2 with same Data ?
29 Feb 2012 08:28 #11 by rdevau
I got the correct apache error log, and i find what was the problem...:
PHP Warning:  Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini. in Unknown on line 0
I set it to 10000, and now it works.
Sorry to have bothered you, if i had the right log from the start...
Big thanks for your help anyway!
Best regards, and bravo for your really good job!
rémi
29 Feb 2012 11:40 #12 by babynus
Thanks for your comments.
Mybe this post will help another user in the future....
