ProjeQtOr free project management software - Error "Calculate activities planning" - Page 2 - ProjeQtOr
27 Feb 2012 15:48 #7 by kiffcool
I still have the error message after one minute.
28 Feb 2012 14:55 #8 by babynus
You must fail in Timeout...
Try to increase max execution time.
Method 1 : in php.ini => Best to do if you have access to it
max_execution_time=300
Method 2 : in /model/palnnedWork.php, line 87 => already done
set_time_limit(300);
If problem persists check for your apache timeout.
02 Mar 2012 11:30 #9 by kiffcool
I did a new test copying database on my local pc.
I've got this error :
Fatal error: Maximum execution time of 300 seconds exceeded in C:\PFL\wamp\www\projectorria\model\persistence\SqlElement.php on line 1335
02 Mar 2012 11:37 #10 by babynus
You fail in Timeout ... at 300s = 5mn ...
1)You can try to inclease value in /model/palnnedWork.php, line 87
set_time_limit(3000);
2) You should try to split you tasks in several sub-project and plan one subproject at a time
3) I'm surprise it takes so long.
I planned some projects with about 50 tasks and it took less than 20 seconds.
Could you anonymyse your Database and send me a copy for testing ?
02 Mar 2012 12:12 #11 by kiffcool
With value
, it's OK in 20 minutes !
02 Mar 2012 14:37 #12 by babynus
Your delay for planning is very very long.
So I tested on my side.
With a Laptop PC, i5 dual core 2,4 GHz, 3Gb RAM, running Easy PHP 5.3, with Apache, PHP, MySQL and Client on same machine.
Planning 25 Activities, all with left work :
First planning = 20s, then each planning = 8s
Planning 50 Activities, all with left work :
First planning = 29s, then each planning = 12s
These delay are much shorter than yours.
As delays are not increasing exponentially with number of activities, I guess your performance is not "normal"
What is the configuration of the Machine your are testing on ?
Can you check the RAM, an watch the swap use during calculation ?
