ProjeQtOr free project management software - Database is empty after installation and no login possible - ProjeQtOr
25 Feb 2012 23:37 #1 by svenn
Installed projectorria v2.0.1 into /var/www on Debian and go through the installation procedure.
I only change the mysql username and password for the user who has root access to mysql.
When pressing 'OK' I get report that everything is ok, and I press the continue button.
I am then taken to the login screen, but I have really no idea which username I should use. I guess the password is the 'projector' one suggested in the setup form.
In the log I see:
2012-02-25 23:02:45 ***** ERROR ***** [1146] SQL Error : Table 'projectorria.parameter' doesn't exist<br/><br/>select * from parameter where parameter.idUser is null and parameter.idProject is null and parameter.parameterCode = 'dbVersion'
2012-02-25 23:02:45 ***** ERROR ***** [1146] SQL Error : Table 'projectorria.menu' doesn't exist<br/><br/>select * from menu where menu.name = 'menuContact'  order by menu.sortOrder
2012-02-25 23:02:45 ***** ERROR ***** [1146] SQL Error : Table 'projectorria.user' doesn't exist<br/><br/>select * from user where user.name = 'admin'
2012-02-25 23:02:45 ===== TRACE ===== Login error for user 'admin'
I inspect the database with phpmysql, and it is created, but there are no tables in the database.
PHP and Apache is installed plain from Debian sid, and I have not modified any parameters yet.
Absolutely no idea where to start looking for my mistake.
Svenn
25 Feb 2012 23:58 #2 by svenn
My bad.
I found more documentation on how to proceed under the demo menu.
There I learned that the initial user/passwd is admin/admin.
Then the database was created and I could log in.
Well, now this case is covered in the forum.
Svenn
