ProjeQtOr free project management software - Error when save RealWorkAllocation - Page 2 - ProjeQtOr
04 Mar 2012 16:56 #7 by babynus
This logged error is not linked to validation isssue : I had these logs without any validation error.
(these log isses are fixed in V2.1)
05 Mar 2012 12:22 #8 by spiderjn
hi babynus
your special file add this log :
2012-03-04 16:16:42 ***** ERROR ***** cause = Undefined index: leftWork_39
best regards
05 Mar 2012 13:21 #9 by babynus
OK,
So now I'm pretty sure : your request is truncated.
Have a look at your apache configuration :
maxParameterCount
maxPostSize
To be sure you may first set these value to 0 (zero = no limit), then try to set best value.
05 Mar 2012 15:28 #10 by spiderjn
hi Babynus
i change MaxPostSize in php.ini to 19M, and i have always same errors.
i control this parameter in /test/info.php, and it's ok.
Best regards
05 Mar 2012 16:07 #11 by babynus
Do you mean post_max_size in PHP.ini ?
I guess the issue is not from php config : you would have a PHP error, clearly logged in log file.
You must look for maxPostSize in httpd.conf, the apache config file.
05 Mar 2012 18:45 #12 by spiderjn
hi babynus
a need add in PHP.ini :
max_input_vars = 2000 ; Disponible depuis PHP 5.3.9. default 1000
now it's working fine.
