ProjeQtOr free project management software - Modifying TimeZone in Global Parameters fail - ProjeQtOr
10 Feb 2026 23:55 - 11 Feb 2026 22:01 #1 by LMen
Do you know if this problem has already been reported?
With a fresh install (but encounter on other previous installs)
default setting : "Africa/Abidjan"
https://photos.mac-yoda.fr/api/assets/8e9ee5fc-c134-42a0-8f88-99383f47b221/thumbnail?key=MCkfM7BsbywYxrCsRW-XV4nQmLokesHyZ2cLTCWUr2WPLZAyTAAgcQ17L-OkLUvvoNw&size=preview&c=tQcODIAgdZlkd4iXiYYgYua%2F1A%3D%3D&edited=true
If I try to change the time zone, an error occurs : "Exception occured" and "detailed error is reported in log file" :
2026-02-10 22:56:20.767 ***** ERROR ***** [V12.4.2] [1] EXCEPTION *****
2026-02-10 22:56:20.769 ***** ERROR ***** [V12.4.2] [1] on file '/var/www/html/model/CronExecution.php' at line (64)
2026-02-10 22:56:20.773 ***** ERROR ***** [V12.4.2] [1] cause = DateTimeZone::__construct(): Unknown or bad timezone ()
2026-02-10 22:56:20.777 ***** ERROR ***** [V12.4.2] [1]    => #0 /var/www/html/model/CronExecution.php (64) -> __construct()
2026-02-10 22:56:20.785 ***** ERROR ***** [V12.4.2] [1]    => #1 /var/www/html/tool/saveParameter.php (327) -> calculNextTime()
Thank you for your feedback.
Last edit: 11 Feb 2026 22:01 by LMen. Reason: Modifying Image attachement method for good display
12 Feb 2026 15:23 #2 by maxca
I'm not sure, but you can check the time zone in your php.init file and also in the Projeqtor parameter database: paramDefaultTimezone.
Have a nice day,
30 Mar 2026 22:29 #3 by LMen
This works correctly by directly setting the parameter value in the database.
Thanks a lot.
