ProjeQtOr free project management software - Authentification Projeqtor avec durcissement Active Directory - ProjeQtOr
22 Dec 2025 08:35 #1 by jerome.moinet@rex-rotary.fr
Bonjour,
Je souhaite durcir la sécurité de mon Active Directory Windows Serveur. Cela passe par entre autre le chiffrement LDAP et le fait de mettre les admins du domaine dans l'OU "Protect User". Or quand je fais cela, Projeqtor n'arrive plus à contacter mon AD:
Le chiffrement LDAP met le message d'erreur authentification renforced required
L'admin du domaine dans Protect User met le message Invalid Credential
La version de Projqtor V12.2.3
Br
22 Dec 2025 17:55 #2 by maxca
Please read the forum rules ( here )and rewrite your message in English.
Have a nice day,
23 Dec 2025 11:38 #3 by jerome.moinet@rex-rotary.fr
Sorry, i write in english. I use authentification Projeqtor with my active directory and I would like to secure it.
For this, i must to activate ldap signing and put my domain admin in the group "Protect User".. But if i done that, authentication projeqtor doesn'y work.
Ldap signing and Pojeqtor say: Error authentification renforced
Domain admin in Protect User and Pojeqtor say: Invalid Credential
Projqtor V12.2.3
19 Jan 2026 18:58 #4 by babynus
Sorry but I don't know this AD feature.
What does it involde in LDAP authentication ?
20 Jan 2026 08:52 #5 by jerome.moinet@rex-rotary.fr
It's for up security about my AD.
LDAP Signing, it's authentification reforced for all connexion
Protect User: it's reserved for admin of domain and disable NTLM for work in full Kerberos. (Maybe i can user classic user in LDAP Information in Projeqtor)
20 Jan 2026 09:15 #6 by babynus
After ready few articles about it, I can answer that ProjeQtOr is not compatible with AD LDAP Signing.
Only solution is to use LDAPS, as projeqtor is compatible with LDAPS (LDAP over TLS/SSL).
The following user(s) said Thank You: jerome.moinet@rex-rotary.fr
