ProjeQtOr free project management software - Errors detected but on object wich does not exist - ProjeQtOr
05 Dec 2025 10:43 #1 by bvd
In Administration panel > search errors, we have some errors detected but about object wich were deleted and does not exist anymore. I dont understand why.
I tried to clean the cache on the brower, change browser, restart application container, check projetqor/cache folder rights and all is ok.
See catpure attached
Any help would be welcome :-)
12 Dec 2025 15:55 #2 by babynus
How did you "delete" the projects ?
You should not be able to delete a project that includes activities ... unles you delete it directly in the DataBase ... and this will sure lead to unconsistencies.
06 Jan 2026 12:11 #3 by bvd
First, I wish you and the entire team of projeqtor a very good new year for 2026 !!
Thank you for tour answer
I manage delete projetcs by 1) assuming no time is registerered in time sheet and if there is, delete time from web ui via timesheet module; 2) delete project from webui and answer yes when projeqtor asks me if i'm sure to delete
regards
19 Jan 2026 19:02 #4 by babynus
Then try and delete erroneous activities referencing these projects
