ProjeQtOr free project management software - Error importing project expense - ProjeQtOr
20 Aug 2025 11:47 - 20 Aug 2025 11:49 #1 by jmmbb
i experience strange issue while importing project expense.
I do it several time in the past and it works but today, i can't find the bug...
ProjeQtOr's version is 12.1.2.
I use a csv file with 8 expenses (first problem become with a largest file but i reduce the number of line to track the bug).
File Attachment:
File Name: Importdpenses.zip
File Size:0 KB
Note : plannedFullAmount, expensePlannedDate, expenseRealDate and realFullAmount are in english to avoid translation's mystake but nothing change.
I use plannedFullAmount to 1 for expenses that are previously set and avoid error with amount = 0.
CP 2025 and aother are personalized flieds with financial value.
I use idProject because, when using project's name i get an error...
So, this is the log after import :
File Attachment:
File Name: projeqtor_...0820.log
File Size:1 KB
And this is the result :
So, fields are well recognized (name of fields are changed to there translation), but i get each time the same error, even with planned date and planned amount not void.
When i try to make it on my 292 expenses to import, i got a time out and log only show "invalid" for each line.
Any idea ?
Best regards,
Last edit: 20 Aug 2025 11:49 by jmmbb.
20 Aug 2025 14:29 - 20 Aug 2025 14:31 #2 by jmmbb
Doing a test with a fresh export structure : copied direct from import screen :
I copy the help line, paste it into excel, set some values according to reference (ie idProject, idStatus, ...) and try to import it, the result is the same :
Even if values are presents :
Last edit: 20 Aug 2025 14:31 by jmmbb.
20 Aug 2025 15:05 - 20 Aug 2025 15:07 #3 by jmmbb
Try to create an expense from ProjeQtOr then export to csv, change value (montant prévu) then try to import : same issue.
Even if i use "tout cocher) to be sure to export every values, can't import csv.
Last edit: 20 Aug 2025 15:07 by jmmbb.
20 Aug 2025 15:08 - 20 Aug 2025 15:12 #4 by jmmbb
Same issue trying in english (perhaps problem with translation ?), so message is in english but no import :) !
Need to set real date and amount : non sense with status "enregistré" !
And even with these value set, import doesn't work !
Last edit: 20 Aug 2025 15:12 by jmmbb.
29 Aug 2025 14:08 #5 by babynus
Issue is that Total Full Amount cannot be imported : it is calculated from ExVAT Amount + Vat Amount (and VAT Amount is calculated from VAT %)
So you need to enter ExVAT Amount and it will calculate Total Full Amount
25 Sep 2025 13:01 - 25 Sep 2025 13:09 #6 by jmmbb
hello,
exVAT Amount or VAT % are not in the fieldqs listed for import.
I put Value in plannedAmount and expensePlannedDate and get the same issue.I put my import file here (amount are example only).
File Attachment:
File Name: Prepa_budg...squs.txt
File Size:1 KB
Last edit: 25 Sep 2025 13:09 by jmmbb. Reason: adding file
