ProjeQtOr free project management software - BUG : Show project level in Ressource planning - ProjeQtOr
30 Apr 2025 14:36 #1 by Lionel70
When you view "Resource Planning" with the "Show Project Level" option (access to additional settings), the project levels appear normally.
Then, if you collapse all the levels with the "-" button (Collapse all groups) and expand them with the "+" button (Expand all groups), the project levels appear briefly and then disappear.
This is not the case if you expand using the "+" button located next to the resource name. In this case, the projet levels appear normaly.
Version is 12.1.1.
Have a nice day,
Lionel
02 May 2025 10:01 #2 by Arkhanje
hello
indeed ! Ticket # 10008 recorded
