ProjeQtOr free project management software - [SOLVED] Issue with date picker and checkbox - ProjeQtOr
12 Mar 2025 15:45 #1 by _vs_equipe_ecm
I have made a migration from version 9.2 to 12.0.1 and also migrate from mysql to postgresql.
Since, I have an issue with date picker and checkbox (see attachment)
Any idea ?
14 Mar 2025 09:12 #2 by Arkhanje
It is possible that the database does not recognize Booleans.
This could be due to a bad build of your database, in which case it would be better to reinstall, or the name of your database was incorrectly entered in the settings.
14 Mar 2025 09:34 #3 by _vs_equipe_ecm
I found the solution. When converting the MySQL dump to PostgreSQL, some types are not the same as in a Postgres database initialized by the application.
After converting the types, the display is correct.
