ProjeQtOr free project management software - timesheet - ProjeQtOr
timesheet
03 Mar 2025 09:14 #1 by pdecloedt
timesheet was created by pdecloedt
version 12.0.1, revision 22418
i find this morning an issue on timesheet.
I would like to put 2h on timesheet for friday 28th febriary. on activity with multi ressource. there is some left work for other ressource.
when i try to record, i received a message who explain that : item can't be "done" with left work ... (I don't want to change the activity status, I just want to charge time)
log file:2025-03-03 08:59:56.593 ***** ERROR ***** [V12.0.1] [13] EXCEPTION *****
2025-03-03 08:59:56.593 ***** ERROR ***** [V12.0.1] [13] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 08:59:56.593 ***** ERROR ***** [V12.0.1] [13] cause = Class name must be a valid object or a string
2025-03-03 08:59:56.593 ***** ERROR ***** [V12.0.1] [13] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 09:04:52.633 ***** ERROR ***** [V12.0.1] [3] EXCEPTION *****
2025-03-03 09:04:52.633 ***** ERROR ***** [V12.0.1] [3] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 09:04:52.633 ***** ERROR ***** [V12.0.1] [3] cause = Class name must be a valid object or a string
2025-03-03 09:04:52.633 ***** ERROR ***** [V12.0.1] [3] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
03 Mar 2025 10:45 #2 by Arkhanje
Replied by Arkhanje on topic timesheet
I am not reproducing.
A resource who finishes his work on an activity does not necessarily finish the time allocated in full on it.
We need more information, the console errors noted do not seem to correspond completely to your problem.
Do you use the dispatch of hours in the imputation sheets? Do you use pools? Have you set constraints on the number of hours to be filled in? Some screenshots of your timesheet and your schedule would be welcome too
03 Mar 2025 11:42 #3 by pdecloedt
Replied by pdecloedt on topic timesheet
we do not use the dispatch hours,
we do not use pool,
no contraints
03 Mar 2025 11:54 #4 by pdecloedt
2025-03-03 09:07:00.999 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image001.png@01DB8C1B.923BCD80
2025-03-03 09:07:00.999 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image002.png@01DB8C1B.923BCD80
2025-03-03 09:07:00.999 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image003.png@01DB8C1B.923BCD80
2025-03-03 09:07:00.999 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image004.png@01DB8C1B.923BCD80
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] HACK ================================================================
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] Try to hack detected
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] Source Code = checkValidAccessForUser() Reject for Project #35 - no 'read' right to this item
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] QUERY_STRING = class=Attachment&id=108&csrfToken=
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] REMOTE_ADDR = 130.93.103.218
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] SCRIPT_FILENAME = /var/www/hosted/biouv_group/tool/download.php
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] CONNECTED USER = #49 - elegac
2025-03-03 09:18:22.734 ***** ERROR ***** [V12.0.1] [49] REQUEST_URI = /tool/download.php?class=Attachment&id=108&csrfToken=
2025-03-03 09:20:57.335 ***** ERROR ***** [V12.0.1] [44] EXCEPTION *****
2025-03-03 09:20:57.335 ***** ERROR ***** [V12.0.1] [44] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 09:20:57.335 ***** ERROR ***** [V12.0.1] [44] cause = Class name must be a valid object or a string
2025-03-03 09:20:57.335 ***** ERROR ***** [V12.0.1] [44] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 09:20:57.469 ***** ERROR ***** [V12.0.1] [44] EXCEPTION *****
2025-03-03 09:20:57.469 ***** ERROR ***** [V12.0.1] [44] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 09:20:57.469 ***** ERROR ***** [V12.0.1] [44] cause = Class name must be a valid object or a string
2025-03-03 09:20:57.469 ***** ERROR ***** [V12.0.1] [44] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 09:26:31.022 ***** ERROR ***** [V12.0.1] [49] HACK ================================================================
2025-03-03 09:26:31.022 ***** ERROR ***** [V12.0.1] [49] Try to hack detected
2025-03-03 09:26:31.022 ***** ERROR ***** [V12.0.1] [49] Source Code = checkValidAccessForUser() Reject for TicketSimple #66 - no 'read' right to this item
2025-03-03 09:26:31.022 ***** ERROR ***** [V12.0.1] [49] QUERY_STRING = class=Attachment&id=87&csrfToken=
2025-03-03 09:26:31.022 ***** ERROR ***** [V12.0.1] [49] REMOTE_ADDR = 130.93.103.218
2025-03-03 09:26:31.023 ***** ERROR ***** [V12.0.1] [49] SCRIPT_FILENAME = /var/www/hosted/biouv_group/tool/download.php
2025-03-03 09:26:31.023 ***** ERROR ***** [V12.0.1] [49] CONNECTED USER = #49 - elegac
2025-03-03 09:26:31.023 ***** ERROR ***** [V12.0.1] [49] REQUEST_URI = /tool/download.php?class=Attachment&id=87&csrfToken=
2025-03-03 09:27:27.425 ***** ERROR ***** [V12.0.1] [13] EXCEPTION *****
2025-03-03 09:27:27.425 ***** ERROR ***** [V12.0.1] [13] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 09:27:27.425 ***** ERROR ***** [V12.0.1] [13] cause = Class name must be a valid object or a string
2025-03-03 09:27:27.425 ***** ERROR ***** [V12.0.1] [13] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 09:44:33.958 ***** ERROR ***** [V12.0.1] [140] ERROR *****
2025-03-03 09:44:33.958 ***** ERROR ***** [V12.0.1] [140] on file '/var/www/hosted/biouv_group/tool/planningColumnSelector.php' at line (84)
2025-03-03 09:44:33.958 ***** ERROR ***** [V12.0.1] [140] cause = Undefined index: show
2025-03-03 10:23:15.412 ***** ERROR ***** [V12.0.1] [108] EXCEPTION *****
2025-03-03 10:23:15.412 ***** ERROR ***** [V12.0.1] [108] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:23:15.412 ***** ERROR ***** [V12.0.1] [108] cause = Class name must be a valid object or a string
2025-03-03 10:23:15.412 ***** ERROR ***** [V12.0.1] [108] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] HACK ================================================================
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] Try to hack detected
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] Source Code = checkValidAccessForUser() Reject for TicketSimple #44 - no 'read' right to this item
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] QUERY_STRING = class=Attachment&id=71&csrfToken=
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] REMOTE_ADDR = 212.114.24.71
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] SCRIPT_FILENAME = /var/www/hosted/biouv_group/tool/download.php
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] CONNECTED USER = #16 - rdegrave
2025-03-03 10:27:23.417 ***** ERROR ***** [V12.0.1] [16] REQUEST_URI = /tool/download.php?class=Attachment&id=71&csrfToken=
2025-03-03 10:27:42.324 ***** ERROR ***** [V12.0.1] [87] EXCEPTION *****
2025-03-03 10:27:42.324 ***** ERROR ***** [V12.0.1] [87] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:27:42.324 ***** ERROR ***** [V12.0.1] [87] cause = Class name must be a valid object or a string
2025-03-03 10:27:42.324 ***** ERROR ***** [V12.0.1] [87] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:27:44.309 ***** ERROR ***** [V12.0.1] [87] EXCEPTION *****
2025-03-03 10:27:44.309 ***** ERROR ***** [V12.0.1] [87] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:27:44.309 ***** ERROR ***** [V12.0.1] [87] cause = Class name must be a valid object or a string
2025-03-03 10:27:44.309 ***** ERROR ***** [V12.0.1] [87] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:30:16.637 ***** ERROR ***** [V12.0.1] [16] EXCEPTION *****
2025-03-03 10:30:16.637 ***** ERROR ***** [V12.0.1] [16] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:30:16.637 ***** ERROR ***** [V12.0.1] [16] cause = Class name must be a valid object or a string
2025-03-03 10:30:16.637 ***** ERROR ***** [V12.0.1] [16] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:36:10.074 ***** ERROR ***** [V12.0.1] [8] EXCEPTION *****
2025-03-03 10:36:10.074 ***** ERROR ***** [V12.0.1] [8] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:36:10.074 ***** ERROR ***** [V12.0.1] [8] cause = Class name must be a valid object or a string
2025-03-03 10:36:10.074 ***** ERROR ***** [V12.0.1] [8] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:42:44.355 ***** ERROR ***** [V12.0.1] [108] EXCEPTION *****
2025-03-03 10:42:44.355 ***** ERROR ***** [V12.0.1] [108] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:42:44.355 ***** ERROR ***** [V12.0.1] [108] cause = Class name must be a valid object or a string
2025-03-03 10:42:44.355 ***** ERROR ***** [V12.0.1] [108] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:42:45.497 ***** ERROR ***** [V12.0.1] [108] EXCEPTION *****
2025-03-03 10:42:45.497 ***** ERROR ***** [V12.0.1] [108] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:42:45.497 ***** ERROR ***** [V12.0.1] [108] cause = Class name must be a valid object or a string
2025-03-03 10:42:45.497 ***** ERROR ***** [V12.0.1] [108] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 10:42:45.842 ***** ERROR ***** [V12.0.1] [108] EXCEPTION *****
2025-03-03 10:42:45.842 ***** ERROR ***** [V12.0.1] [108] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 10:42:45.842 ***** ERROR ***** [V12.0.1] [108] cause = Class name must be a valid object or a string
2025-03-03 10:42:45.842 ***** ERROR ***** [V12.0.1] [108] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 11:01:05.904 ***** ERROR ***** [V12.0.1] [16] EXCEPTION *****
2025-03-03 11:01:05.904 ***** ERROR ***** [V12.0.1] [16] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 11:01:05.904 ***** ERROR ***** [V12.0.1] [16] cause = Class name must be a valid object or a string
2025-03-03 11:01:05.904 ***** ERROR ***** [V12.0.1] [16] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] HACK ================================================================
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] Try to hack detected
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] Source Code = Invalid class name 'Gvdxfg'
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] QUERY_STRING = directAccess=true&objectClass=Gvdxfg&objectId=3606
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] REMOTE_ADDR = 40.89.180.146
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] SCRIPT_FILENAME = /var/www/hosted/biouv_group/view/main.php
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] CONNECTED USER = # -
2025-03-03 11:04:28.372 ***** ERROR ***** [V12.0.1] REQUEST_URI = /view/main.php?directAccess=true&objectClass=Gvdxfg&objectId=3606
2025-03-03 11:12:03.962 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image001.jpg@01DB8C2D.06B035F0
2025-03-03 11:12:03.963 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image002.png@01DB8C2D.06B035F0
2025-03-03 11:12:03.963 ***** ERROR ***** [V12.0.1] Base64 Encoding of image - Could not read file cid:image003.png@01DB8C2D.06B035F0
2025-03-03 11:23:45.470 ***** ERROR ***** [V12.0.1] [87] EXCEPTION *****
2025-03-03 11:23:45.470 ***** ERROR ***** [V12.0.1] [87] on file '/var/www/hosted/biouv_group/model/Security.php' at line (413)
2025-03-03 11:23:45.471 ***** ERROR ***** [V12.0.1] [87] cause = Class name must be a valid object or a string
2025-03-03 11:23:45.471 ***** ERROR ***** [V12.0.1] [87] => #0 /var/www/hosted/biouv_group/tool/download.php (65) -> checkValidAccessForUser()
