ProjeQtOr free project management software - First connexion - ProjeQtOr
First connexion
25 Feb 2025 14:42 #1 by darius95
First connexion was created by darius95
I've just installed the Projqtor program.
When I launch the program for the first time, I get the following message: “Update in progress
Only an administrator can connect”.
By entering the commanded credentials
login : admin
Password : admin
Incorrect connection parameters
When I connect to PhpMyAdmin, the projeqtor's database is empty.
Thank you for your help
26 Feb 2025 16:32 #2 by maxca
Replied by maxca on topic First connexion
can you post your log files?
02 Mar 2025 14:16 #3 by darius95
Replied by darius95 on topic First connexion
maxca post=38540 wrote: Hello,
log
2025-03-02 14:06:17.933 ===== TRACE ===== Migrating from version < V4.0.0 : previous errors are expected for Class 'User' on fields 'loginTry', 'salt' and 'crypto'
2025-03-02 14:06:17.934 ===== TRACE ===== Login error for user '“’<X'
04 Mar 2025 09:31 #4 by maxca
does your database name match the name in files>config>parameters.php '$paramDbName'?
06 Mar 2025 11:28 #5 by darius95
hello
yes
It s the same name
09 Mar 2025 17:12 #6 by darius95
hello
yes
It s the same name
have you an idea ?
