ProjeQtOr free project management software - Project : closed status does not lead to close project - ProjeQtOr
03 Feb 2025 13:34 - 03 Feb 2025 13:38 #1 by jmmbb
i'm facing this issue : i change status of project to "décommissionné" wich is a "closed" status :
The project is moved to status "décommissionné" but is not closed, only closed date is set but not status :
Note : if i set closed manually, ProjeQtOr said :
But nothing when changing status.
If y say "Yes" to the queqstion, status is correctly set for project and associated milestones.
Last edit: 03 Feb 2025 13:38 by jmmbb.
08 Feb 2025 11:48 #2 by babynus
Possibly the Milestones cannot bez closed for some reason.
Try and close them manually one by one.
