ProjeQtOr free project management software - Chronology partialy visible - ProjeQtOr
06 Dec 2024 14:43 - 06 Dec 2024 14:44 #1 by jmmbb
Can reproduce on DEMO :
When selecting more than 3 elements in chronology, they can't be seen at same time, sidebar appear in chronology (i set max lines in chronology to 10 and reload page).
Last edit: 06 Dec 2024 14:44 by jmmbb.
11 Dec 2024 15:24 #2 by babynus
Replied by babynus on topic Chronology partialy visible
They are displayed !
But the timeframe for "bug fixing" is from 2011 to 2024.
So a 2 days long tasks appears only as a small line and is almost not visible
11 Dec 2024 16:19 #3 by jmmbb
Replied by jmmbb on topic Chronology partialy visible
Yes but, even i select :
- Project One
- Project One maintenance
- Project One development
- Evolution X - Analysis
- Project Two
- Project two - Management
And set Max line in timeline to 15,
I can only see 3 lines on timeline and need to use scrolling to see all of them.
12 Dec 2024 09:14 #4 by babynus
Yes, it is designed this way : Timeline area is restricted to 3 visible lines. Idea is to preserve space for main planning part (gantt).
Then you can select how many lines will be visible, but not without scrolling.
Note that Timeline is not designed to show projet, parent activity and sub-activities.
The pûrpose of the timeline is to be able to see several tasks on same line, so you should not need so many display lines.
13 Dec 2024 10:37 #5 by jmmbb
Is it possible to given ability to show more line in timeline, so it can be used (via copy/paste) in some documents (like strategical presentation) ?
17 Dec 2024 09:40 #6 by Arkhanje
We have not planned this possibility, the timeline not being the most used tool on the planning screen.
But do not hesitate to ask for a quote for a possible development via the form on our site!
