ProjeQtOr free project management software - SAML connection attribute problem (11.4.2) - ProjeQtOr
29 Nov 2024 12:01 #1 by Virgile
We would like to set up a SAML connection with our ADFS. The connection parameters to our adfs are correct and the projeqtor adfs has been added. We want the connection to be made with the sAMAccountName attribute, but we're getting an “Undefined array key ‘sAMAccountName’ in SSO.php at line 106” error. No matter what the attribute name, it tells us “Undefined array key ‘XXXX’ in SSO.php at line 106”.
What attribute do we need to set for this to work?
Thank you in advance.
Best regards,
Virgile.
11 Dec 2024 14:26 #2 by babynus
Check the xml file returned by your sso connection.
You'll see all available fields returned by your sso.
18 Dec 2024 14:08 #3 by Virgile
The xml you mention is the xml we get like this: adfs.com/FederationMetadata/2007-06/FederationMetadata.xml ?
I tried with the name :
schemas.NotAllowedScript69d0ea21898cemicrosoft.com/ws/2008/06/identit...s/windowsaccountname
with its FriendlyName:
Windows account name
but still with the same problem.
Best regards,
Virgile.
20 Dec 2024 19:56 #4 by babynus
No, I mean the XML file returned from SSO after login.
You can open browser console / network to check response from SSO
04 Feb 2025 15:47 - 04 Feb 2025 15:48 #5 by Virgile
I get the following error when I try to connect using SAML:
ERROR: Undefined array key “NameID”
in SSO.php
at line 106
It doesn't matter which attribute is set on projeqtor, it tells me it's not defined.
I've looked at the XML sent by our ADFS and the NameID is indeed present:
<Subject>
<NameID Format=“urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified”>ABCD1\VUSER</NameID>
<SubjectConfirmation Method=“urn:oasis:names:tc:SAML:2.0:cm:bearer”>
<SubjectConfirmationData InResponseTo="ONELOGIN_36eb332480cf8b15c6f59e48a313039d8c3bc329”
NotOnOrAfter="2025-02-04T13:51:58.395Z”
Recipient="projeqtor.fr/sso/projeqtor/index.php?acs
</SubjectConfirmation>
</Subject>
Do you have an idea?
Best regards,
Virgile.
Last edit: 04 Feb 2025 15:48 by Virgile.
08 Feb 2025 12:28 #6 by babynus
Add one debug line after line ~267 in tool/projeqtor.php
$authAttr = $_SESSION['samlUserdata'];
debugLog($authAttr);
Then set debug Mode in Adminsitration.
Finaly try and connect
You'll get a trace of all available fields.
