ProjeQtOr free project management software - Error after subscription manual update - Page 2 - ProjeQtOr
24 Nov 2024 17:13 - 24 Nov 2024 17:17 #7 by karl.binet
Hi
i tried doing a manual update again
Here is my projeqtor log file, there is nothing about the manual update in it
2024-11-24 09:32:19.990 ===== TRACE ===== [27] NEW CONNECTED USER 'karl.binet'
2024-11-24 09:35:29.385 ===== TRACE ===== Cron started at 24/11/2024 09:35:29
2024-11-24 09:35:30.833 ===== TRACE ===== Logfile->purge() : Technical trace to keep current log file
2024-11-24 10:56:40.332 ===== TRACE ===== [27] NEW CONNECTED USER 'karl.binet'
here is the content of apache error.log files
[Sun Nov 24 10:56:31.398068 2024] [mpm_prefork:notice] [pid 1359:tid 1359] AH00163: Apache/2.4.62 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Sun Nov 24 10:56:31.398085 2024] [core:notice] [pid 1359:tid 1359] AH00094: Command line: '/usr/sbin/apache2'
[Sun Nov 24 10:58:02.356645 2024] [php7:warn] [pid 1475:tid 1475] [client 10.1.120.51:54246] PHP Warning:  session_start(): Failed to decode session object. Session has been destroyed in /var/www/html/tool/projeqtor.php on line 46, referer: gp.regiscote.com/view/main.php
[Sun Nov 24 10:58:02.356679 2024] [php7:error] [pid 1475:tid 1475] [client 10.1.120.51:54246] PHP Fatal error:  Uncaught Error: Class 'Parameter' not found in /var/www/html/tool/projeqtor.php:3039\nStack trace:\n#0 /var/www/html/tool/projeqtor.php(3170): logTracing()\n#1 /var/www/html/tool/projeqtor.php(1687): errorLog()\n#2 /var/www/html/model/_securityCheck.php(41): traceHack()\n#3 /var/www/html/model/Menu.php(30): require_once('/var/www/html/m...')\n#4 /var/www/html/tool/projeqtor.php(1811): require_once('/var/www/html/m...')\n#5 [internal function]: projeqtorAutoload()\n#6 [internal function]: spl_autoload_call()\n#7 /var/www/html/tool/projeqtor.php(46): session_start()\n#8 /var/www/html/tool/saveCollapsed.php(30): require_once('/var/www/html/t...')\n#9 {main}\n  thrown in /var/www/html/tool/projeqtor.php on line 3039, referer: gp.regiscote.com/view/main.php
[Sun Nov 24 10:58:15.903497 2024] [php7:error] [pid 2583:tid 2583] [client 10.1.120.51:54280] PHP Fatal error:  Uncaught Error: Class 'Parameter' not found in /var/www/html/tool/projeqtor.php:1531\nStack trace:\n#0 [internal function]: exceptionHandler()\n#1 {main}\n  thrown in /var/www/html/tool/projeqtor.php on line 1531, referer: gp.regiscote.com/view/main.php
[Sun Nov 24 10:58:15.935796 2024] [php7:error] [pid 2585:tid 2585] [client 10.1.120.51:54281] PHP Fatal error:  Uncaught Error: Class 'Parameter' not found in /var/www/html/tool/projeqtor.php:1531\nStack trace:\n#0 [internal function]: exceptionHandler()\n#1 {main}\n  thrown in /var/www/html/tool/projeqtor.php on line 1531, referer: gp.regiscote.com/view/main.php
You want me to post some file that were upgraded, well, after the update, all the files that were upgraded are empty
Please note that, in the past, i used manual updated 1 time and i work perfectly. this was before updating to 11.4.2
Last edit: 24 Nov 2024 17:17 by karl.binet.
24 Nov 2024 17:57 #8 by babynus
Thanks for sharing the issue report.
In fact it seems you cannot retreive data from projeqtor server.
I just tested right now and upgrade runs like a charm, no issue.
It seems your server cannot acces projeqtor server, but weird you can check subscription code (on same server) that is executed on every access of the subscription page.
Do you have any error or trace in Projeqtor log file ?
24 Nov 2024 18:07 #9 by karl.binet
No nothing was added in the projeqtor log files after update, you can see the content of the projeqtor log file on the top of my previous post.
24 Nov 2024 18:11 - 24 Nov 2024 18:12 #10 by karl.binet
hi, would like to inform you also, that, before i do an update i'm doing a virtal machine snapshot,
so, i did the snapshot
tried manual update, did not worked
Revert back the snapshot
But after reverting the snapshot, i opened back Projeqtor, went to subsription and i was no longuer registered with server, i could no longuer get the update
i reverted the snapshot one more time, and this time, when i opened Projeqtor, my subscription was OK.
i Don't know if it's related, but i tought you should know.
Last edit: 24 Nov 2024 18:12 by karl.binet.
