ProjeQtOr free project management software - [SOLVED] Advanced filter: product versions visible although in closed state - ProjeQtOr
09 Nov 2024 17:29 - 09 Nov 2024 17:34 #1 by Tony44
On the advanced filter screen, for example from tickets, the product versions (origin or target) remain visible even though they are in "closed" state. This seems incorrect (the "magnifier" button allows you to search for closed items if necessary).
Other items (planning activity, product, ...) are hidden on this screen when they are in "closed" state.
Moreover, there is a small display problem (overlap) on this screen, see circled part on the screenshot below.
Release: 11.4.2
Thanks!
Tony44
Last edit: 09 Nov 2024 17:34 by Tony44. Reason: Added screenshot
18 Nov 2024 12:08 #2 by babynus
Issue recorded as Ticket #9203
19 Mar 2025 23:48 #3 by Tony44
Ok in V12.0.2, thanks
Tony44
