ProjeQtOr free project management software - Resource Planning filter bug - ProjeQtOr
16 Sep 2024 15:09 - 16 Sep 2024 15:11 #1 by ddal
in Resource Planning after selecting someone in the resource filter there is an alert "No data to display". If you select (event the same project or all projects) from projects menu in to top left corner the data will refresh correctly. The same happens when using any filters.
using version v11.3.2 but happens for a while now.
Last edit: 16 Sep 2024 15:11 by ddal.
17 Sep 2024 16:03 #2 by babynus
I cannot reproduce this behavior.
Are you sure the selected resource has assignment on the selected projet ?
If you select all projets before opening Resource planning, the select resource, is display OK ?
17 Sep 2024 16:06 #3 by ddal
Replied by ddal on topic Resource Planning filter bug
yes, the view is fine when you open it the first time. It's just when you apply a filter it will say there is no data, but when you force it to refresh the view for instance by reselecting a project (even tho it has been selected the whole time) is refreshes it with the filter correctly
25 Sep 2024 14:19 #4 by babynus
I cannot reproduce.
What I get just after selecting a resource is correct
What version are you using ?
Can you try and set use cas on Demo ?
25 Sep 2024 15:26 #5 by ddal
11.3.2. But it happens pretty much in any version. I tried it with users having less projects and team members visible, and it works. So it's possibly something with users having lots of projects visible. It just returns No Data from the jsonResourcePlanning.php endpoint and there is nothing interesting logged, so i'm not sure how i can debug it further.
25 Sep 2024 15:27 - 25 Sep 2024 15:27 #6 by babynus
Please try and reproduce on demo so that we can share a use case.
Last edit: 25 Sep 2024 15:27 by babynus.
