ProjeQtOr free project management software - meeting with or without left hours - ProjeQtOr
02 Sep 2024 10:33 #1 by pdecloedt
I've got a probleme, I'd change, on time sheet, the left of this meeting, but the left on progress section don't change and, I cannot close this meeting.
04 Sep 2024 10:29 #2 by Arkhanje
Have you tried to directly change the status of the meeting by putting it on the last status of your workflow, which should be linked to an item closure?
04 Sep 2024 10:41 #3 by pdecloedt
 I just tr to put on workflow "Done"... same issue...
05 Sep 2024 11:08 #4 by babynus
Try and manually update Assignment table : add  1 assigned day (this will add 1 left day).
Remove the added day.
Left work should be recalculated
05 Sep 2024 12:47 #5 by pdecloedt
impossible to had some assignement hours...
I put in, mechanic wheel turn long time... and nothing change...
and nothing on the log file...
17 Sep 2024 11:29 #6 by babynus
Do you have errors in browser console ?
