ProjeQtOr free project management software - [SOLVED] Tag Selection doesn't work on Planning - ProjeQtOr
06 May 2024 14:13 #1 by jmmbb
in Planning view, advanced filters propose tags as criteria.
But entering tags = <value> doesn't restrict project list to project with tags <value>.
For example, i set tags testselect1 for projet one and testselect2 for project two.
I open planning and create custom filter as "tags contient testselect1".
All projects remains visible :
If i quit planning and come back, no project are shown. I need to suppress filter to get project :
06 May 2024 14:15 #2 by jmmbb
PS : work fine in project list :
10 May 2024 18:24 #3 by babynus
All filters in Planning apply on Activities, so youi'll get Activities with the tags.
13 May 2024 16:05 #4 by jmmbb
Thanks,
so, if i use tags to mark some projects i have to reprot it on every project activities.
I see it is not too difficult to do that throught multiple update for activities.
14 May 2024 09:27 #5 by babynus
Other option : use project selector
 - search for projects with the project selector option
 - apply filter on tags
 - select all and validate selection
You have selected all the projects you want, you can now go to Planning and see only activities of these projects...
