ProjeQtOr free project management software - V11.1.5 : problem with layout management : id move to end - ProjeQtOr
16 Apr 2024 10:04 #1 by jmmbb
i get a new issue (again ???).
While saving layout for project, id column is moved to end of fields.
Here is the process
I set a layout :
I use layout management and save it, so i get this after saving :
Save is ok, i can relaod the layout (with id in last column...).
Nothing in log nor console.
16 Apr 2024 13:02 #2 by maxca
I can't reproduce your problem.Can you move the id before the name? then save it again
Maxca
17 Apr 2024 16:39 #3 by jmmbb
I do it many times...
It doesn't append on every list, but only on Project.
Some issue with custom fields ?
19 Apr 2024 15:50 #4 by babynus
Cannot reproduce.
Can you please try reset the layout, then redifine the layout you want and save it.
