ProjeQtOr free project management software - [SOLVED] Can't connect after using API - ProjeQtOr
29 Mar 2024 08:23 #1 by jmmbb
i use API to get data and, after, i can't reconnect to ProjeQtOr.
I get this error :
2024-03-29 08:20:00.676 ===== TRACE ===== 'user' was connected through API and should not reach Application for same session. May be a hacking attempt from IP ::1
2024-03-29 08:20:00.676 ===== TRACE ===== IP CLient=::1
2024-03-29 08:20:00.677 ===== TRACE ===== $_REQUEST[xcurrentLocale]=en
2024-03-29 08:20:00.677 ===== TRACE ===== $_REQUEST[currentWidth]=1620
2024-03-29 08:20:00.678 ***** ERROR ***** [V11.2.0] EXCEPTION *****
2024-03-29 08:20:00.678 ***** ERROR ***** [V11.2.0] on file 'C:\xampp\htdocs\tool\projeqtor.php' at line (215)
2024-03-29 08:20:00.679 ***** ERROR ***** [V11.2.0] cause = Tentative d'accès invalide
2024-03-29 08:20:00.679 ***** ERROR ***** [V11.2.0]    => #0 C:\xampp\htdocs\view\main.php (38) -> require_once()
04 Apr 2024 09:36 - 04 Apr 2024 09:37 #2 by babynus
You should not use API call from same browser as current connection on ProjeQtOr on same server / instance
Last edit: 04 Apr 2024 09:37 by babynus.
04 Apr 2024 11:43 #3 by jmmbb
Replied by jmmbb on topic Can't connect after using API
I'd noticed that but i think that it will be good after closing the tab.
In fact, i need to close the browser.
Thanks,
