ProjeQtOr free project management software - [SOLVED] Project selector with autocompletion hard to use - ProjeQtOr
15 Feb 2024 16:15 #1 by jmmbb
when using autocompletion mode for project selector, it's hard to use it because if your project is sub of another it is set as _PROJECT.
With search, it doesn't matter because "PROJ" return _PROJECT.
But, with autocompletion, you have to know that PROJECT is a sub-project to enter "_PRO".
And if PROJET is sub of a sub, remember to start with "__", and so on...
Searching by autocompletion without the left "_" will be fine to find our projects !
Expect to be clear.
19 Feb 2024 20:22 #2 by babynus
This is not possible as this is driven by the component (Filtering Select)
That's why we propose 2 list styles, one with autocompletion, for users with a flat project structure, and one with search, that fits tree structures (but looses autocompletion)
The following user(s) said Thank You: jmmbb
