ProjeQtOr free project management software - Problem with "fresh install" on V11.1.3 - ProjeQtOr
12 Feb 2024 11:56 #1 by jmmbb
i'm doing a "fresh" install of V13.1.3 from zip.
Configuration screen are correctly loaded and i set all paramters, then i get the message "next screen connect as admin/admin", then :Not FoundThe requested URL /view/view/index.php was not found on this server.
It seems there's a mistake with redirect with /view/view...
Tried to remove
chdir(dirname(__FILE__).'/view');
from ./view/index.php but no better...
Any idea ?
12 Feb 2024 12:00 #2 by babynus
Please sent it to us !!!!
We'll save about 2 years of work.
12 Feb 2024 12:02 #3 by babynus
About your issue, I think you reached page
https://yourserver/projeqtor/view/main.php
instead of just
14 Feb 2024 20:35 #4 by jmmbb
Install is on html directory and access directly via https://projeqtor. (projeqtor is the A entry for DNS).
Can't investigate more and doing a new install with V 11.0.1 and upgrade...
14 Feb 2024 20:38 - 14 Feb 2024 20:38 #5 by jmmbb
Noooo !
I disinstall it to get back from V 11.0.1.
All is lost on V13 :):):) !
Last edit: 14 Feb 2024 20:38 by jmmbb.
