ProjeQtOr free project management software - [SOLVED] Issue with tabs in detail screen - Page 2 - ProjeQtOr
15 Feb 2024 16:35 #7 by LaurenceB
Many thanks,
It is now solved.
For the record (in case others have the same issue) :
When I removed the line, the initial issue reappeared and I could not find the php.ini file to try the second option described in www.projeqtor.org/fr/forum-fr/5-ask-ques...creating-new-clients.
In fact, on the server I use, the « zlib.output_compression » parameter is in the « .user.ini » file in the root folder. After setting the parameter to « Off », everything was working again.
