ProjeQtOr free project management software - Fixed milestone move and does not "return" to place - ProjeQtOr
07 Feb 2024 16:52 - 07 Feb 2024 16:54 #1 by jmmbb
when planning with fixed milestone, it will be moved if predecessor is set with end date post milestone date (this can be understood with milestone set to "late").
But, if prédecessor is removed, milestone doesn't return to fixed date.
I Explain :
First, i set a "fixed" milestone
Then, this milestone is linked to a predecessor and the date is calculed according to this link (why not, it's a choice, and milestone is set to "late" and show red).
After that, link is deleted (i don't want it anymore or linking is a mistake) : but planning date is not changed and milestone doesn't "return" to his place. And i can't change it (planning date is set so milestone is not recalculated...)
Last edit: 07 Feb 2024 16:54 by jmmbb.
07 Feb 2024 16:56 #2 by jmmbb
I can't find a way to set the correct planning date anymore, i need to delete and recreate the milestone or create a new one, fixed, to the right date and link it as predecessor then delete it...
08 Feb 2024 08:43 #3 by Arkhanje
We do not reproduce. The milestone remains fixed and does not change date even after setting a predecessor that ends later...
What version of ProjeQTOr are you on?
Do you have any error messages? Interface, ProjeQtor logs, browser console?
08 Feb 2024 09:08 #4 by babynus
Do you have a way to reproduce the case on the Demo DB ?
10 Feb 2024 12:12 #5 by jmmbb
strange, i can't reproduce on demo and, after deleting the "wrong" milestone, not able to reproduce anymore on my instance (fresh install V11.1.3).
No explain...
12 Feb 2024 09:08 #6 by Arkhanje
It’s Bonaldi’s law!
It happens to me all the time too! In any case, it worked out, that’s the main thing!
Time to create page: 0.075 seconds
