ProjeQtOr free project management software - [SOLVED] max_input_vars - ProjeQtOr
26 Jan 2024 15:51 #1 by ELu
max_input_vars was created by ELu
HI,
We'got this message with only one user.
Do you know this issue.
Do we have tio change the php.ini file ?
Thank you
26 Jan 2024 16:09 #2 by Plucks
Replied by Plucks on topic max_input_vars
This is not exactly an issue with ProjeQtOr : that only means you're trying to display too many fields on your timesheet page for this user.
You can either change the value in the php.ini file as suggested in the warning or you can also check if this user has the right activities to fill in and if he really needs all of them at the same time (too many lines to search in may not be really efficient when it comes to fill in the time spent).
Also, you may try to switch from the month view to the week view (less fields to display).
The following user(s) said Thank You: ELu
