ProjeQtOr free project management software - [SOLVED] upload_max_filesize - ProjeQtOr
24 Jan 2024 11:41 #1 by ELu
upload_max_filesize was created by ELu
Hi, i don't success to increase the upload max filesize.
I open the global parameters and try several ways : 5M, 5000K, ...
No success.
Can you help me ?
24 Jan 2024 11:53 #2 by Plucks
Replied by Plucks on topic upload_max_filesize
First, be sure to save the configuration you change in global parameters, using either Ctrl+S or click on the disk in the upper right corner.
Also, of course, as written in the online manual of ProjeQtOr , in order for the change to be valid, the size selected in global parameters must be smaller or equal to php parameter “upload_max_filesize”. You can find this parameter in your php.ini config file on your web server.
Hope this helps.
