ProjeQtOr free project management software - Import of milestones impossible : need ValidatedDuration (doesn't exist for) - ProjeQtOr
12 Jan 2024 09:55 #1 by jmmbb
i'm trying to import data from other Project Management system into ProjeQtOr. (V11.0.1).
When trying to import MileStone, i get this error : "Field 'validated duration' is mandatory. This is a non sense for a milestone witch don't have duration... and even if i describe such a field in the import file, it's not ok.
So, can't import milestone...
When i try to export existing milestone no such field appears in the result csv (logical...).
15 Jan 2024 10:16 - 15 Jan 2024 10:45 #2 by jmmbb
New problem : expect validated start date, present but not read.
See import result :
csv Import files attached.
File Attachment:
File Name: 2024015Imp...lons.txt
File Size:0 KB
Last edit: 15 Jan 2024 10:45 by jmmbb.
15 Jan 2024 19:39 #3 by babynus
I think it is the planning mode which is not correctly set, possibly not fitting a milestone planning mode.
Best is to export an existing milstone to get correct expected format.
16 Jan 2024 09:34 #4 by jmmbb
it's exactly that i done... :(
