ProjeQtOr free project management software - Tickets created by input mailbox get initial state "Copied" - ProjeQtOr
10 Jan 2024 08:14 #1 by RoBra81
since update to version V11.1.1 the tickets created by input mailbox are getting the initial state "Copied" which in my opinion isn't correct.
Thank's
Ronny
10 Jan 2024 10:36 #2 by Arkhanje
We do not reproduce.
The tickets received in the email box are in the first state of the workflow "recorded" and not in the "copied" status.
Did you have any update problems? Did you have any errors in the logs?
10 Jan 2024 12:04 #3 by RoBra81
I had no problems during update and no error within the log. I can't find a state "copied" within our configuration (I think it's an internal state) and since we use german interface with translated states, we don't have a state or workflow "recorded". Workflow used for tickets is "Default" and first state (ID 1) is "angelegt".
11 Jan 2024 19:16 #4 by babynus
It seems there is an issue.
We create on status "copied" to store followed before moving to status recorded.
But if option 'add recipient to followers' is not checked, the ticket is kept in status "copied".
Will be fixed
