ProjeQtOr free project management software - How to export / import & replace assigments? - Page 2 - ProjeQtOr
05 Dec 2023 11:45 #7 by loicr
Replied by loicr on topic Gantt planning report
Strange, it works under EDGE vs Chrome !
05 Dec 2023 11:47 #8 by loicr
But only for single project, if i select master planning ... red notice.
LR
05 Dec 2023 11:59 #9 by loicr
After reboot and correction in one project with ressources closed deleted.
It seems to work.
Thanks !
LR
05 Dec 2023 13:54 #10 by Arkhanje
You can also use PDF export from the planning view. It's the same result but you can format it differently.
In addition, this report will disappear since export is more efficient
